RC RC receiver input into PIC16f627 to turn LED on
vane
Joined Feb 28, 2007
189
Basically, what i would like help on is the simple logic behind how you go about measuring 1ms - 2ms pulses every 20ms. I would preferably need help with assembly as that is the program i am currently using
At the moment I only know how to do it with just one push button
Rich (BB code):
EFFECT_1	BTFSC	PORTA,SW1
		GOTO	EFFECT_1
E1		MOVLW	B'00100000'	;
		MOVWF	PORTB
		CALL	DELAY_ROUTINE
		MOVLW	B'00110000'	;
		MOVWF	PORTB...
Any help would be greatly appreciated.
vane
Joined Feb 28, 2007
189
I have just tried an example on the internet but it wont flash an LED. How do you know if your chip has burnt out?
EDIT: No, it hasn't burnt out, i think i have a faulty DIL socket on my experiment board
Thanks so much for that web link! i will examine it thoroughly in the morning!
vane
Joined Feb 28, 2007
189
Anyone know why i cant call my subroutines in this code?
Rich (BB code):
;Constants
08h	equ	C8h		;Set COUNT1 number (200)
09h	equ	Ah		;Set COUNT2 number (10)
STATUS	equ	03h                 ;Address of the STATUS register
TRISA	equ	85h                 ;Address of the tristate register for port A
PORTA	equ	05h                 ;Address of Port A
COUNT1	equ	08h                 ;First counter for delay loops
COUNT2	equ	09h                 ;Second counter for delay loops
;Port Setup
	bsf	STATUS,5	;Bank 1
	movlw	01h		;Send to W
	movwf	TRISA		;Send w to TRISA
	bcf	STATUS,5	;Bank 0
;Check if it is jumpered
Start	movlw	01h
	movwf	PORTA
	BTFSC	PORTA,0		;see if it is high
	call	1msDelay
;1ms delay
	call	1msDelay
;Now switching to low for 20ms pulse
	movlw	00h
	movwf	PORTA
;20ms Pulse
ROUTINE	COUNT	equ 20
LABEL21	decfsz	COUNT,1
	Goto	LABEL21
;Restart
	goto	Start
;Subroutines;
1msDelay
Loop1	decfsz	COUNT1,1     ;This second loop keeps the LED
	goto	Loop1              ;turned off long enough for us to
	decfsz	COUNT2,1      ;see it turned off
	goto	Loop1              ;
return
Apparently there are 10 errors in this, i can't find them :s
bertus
Joined Apr 5, 2008
22,277
Is a label not supposed to have a semicolon ":" behind it?
So use,
1msDelay: as label (also with other labels used).
Greetings,
Bertus
jpanhalt
Joined Jan 18, 2008
11,087
So use,
Greetings,
Bertus
I use MPLAB IDE and no colon (or semicolon) is used after labels. The semicolon sets off comments.
I have a very similar program that works. It would be helpful if Vane would give more detail about how he knows it is not working? For example, is it not compiling, can he step through it, what errors is he getting, and so forth.
John
jpanhalt
Joined Jan 18, 2008
11,087
Here is a screen print of a portion of the code. Sorry for the fuzziness, I wanted to use the screen print so the exact format and colors would be preserved. Note the subroutine calls and returns (retlw).
John
jpanhalt
Joined Jan 18, 2008
11,087
Ah, your "return" is in the wrong column. Tab it over one. Also, my compiler complains when I use "return", but still works, as I recall. Use "retlw 0"
John
vane
Joined Feb 28, 2007
189
Right done that, but that hasn't stopped it saying any other of the errors
I am just using Notepad to write it and using MPASMWIN to compile
jpanhalt
Joined Jan 18, 2008
11,087
What are the other errors?
Everyone has his own preference. I have tried notepad, but get some dumb errors. MPLAB helps in format and spelling. If the instruction is wrong, it won't change to blue and so forth.
John
jpanhalt
Joined Jan 18, 2008
11,087
Here are a couple of quick obserbvations:
1) Labels must begin with an alpha character or underscore. That takes care of some of the errors.
2) At least one error was simple misspelling.
Try fixing those and see what happens.
John
vane
Joined Feb 28, 2007
189
For some reason it does not look like it accepts:-
Rich (BB code):
After this it has 1 more error
jpanhalt
Joined Jan 18, 2008
11,087
I think that is the wrong way to put a value into a register. Go to the code I posted and look at the section beginning Dly_120.
In other words, your equates should look something like:
d1 equ 08h
d2 equ 09h
Then in your code you will have something like:
Rich (BB code):
       clrwdt           ; it's a good idea to clear the wdt
       movlw     c8h     ;  puts d'200 in w
       movwf     d1  ;puts the value in w into the register you have  defined for d1, namely 08h
PS: Sorry for the lousy looking code. I haven't got the knack of writing it in Notepad and posting with the code tags.
John
jpanhalt
Joined Jan 18, 2008
11,087
Where you put it depends on how you are going to use it. I just set up d1, d2, d3, etc. in the equates. Then when I need a delay, I load the correct values in each register. That is, those few registers take care of all of my delays.
I use a Delay Code Generator on the Internet to calculate nested delay loops. That generator uses d1, etc., and I saw no reason to change. I just cut and paste, then tweak using the simulator and stopwatch functions, if needed. However, for what I was doing, it was close enough ±2 cycles.
John
Edit: Here's a link to the code generator: http://www.piclist.com/techref/piclist/codegen/delay.htm
vane
Joined Feb 28, 2007
189
haha, i went through all the workings out! working out if it has a 20mhz clock, 1 millisecond is 2000 cycles!
jpanhalt
Joined Jan 18, 2008
11,087
With a PIC, a cycle is f/4 or 1/5 x10E-6 seconds per cycle with a 20 MHz clock. Thus, 5000 cycles x 1/5 x10E-6 = 0.001 seconds.
John
