RC Phase Oscillator
Discussion in 'Homework Help' started by blin, Jan 9, 2012.
  1. blin
    Jan 9, 2012
    Hi guys
    i am stuck on this assignment.
    the question is the following:
    Design an RC phase oscillator and use operational amplifiers to condition the output
    signal of the oscillator to produce concurrent sine and cosine waveforms.
    The output voltage is also to be made variable from ±1V to ±5V. You will each be given a
    fixed oscillator frequency
    a frequency of 200Hz has been given but i dont know where to go from here.
    please someone help because i am stuck nd dont know where to go from here.
    ive designed oscilliator using formula 1 over 2x pi x R x C x square root of 6
    i have uploaded my design please get back ASAP
  2. PaulEE
    Dec 23, 2011
  3. Adjuster
    Dec 26, 2010
    Your output amplifier uses an inverting configuration with quite a low input resistance. This may complicate the design of your feedback network due to loading effects.
    Perhaps you should consider increasing the resistor, or changing to a non-inverting configuration.
