what im trying to achieve is to make a radio controlled set of direction indicators...
when steering right 2 leds flash
when steering left 2 different leds flash.
I was originally looking at using the 10f206, because of its size and i have some lurking around. i know its more than capable of preforming the tasks needed. using more than one pic isnt a problem, but want to keep them small.
The receiever already in the remote control truck uses PPM, so i need it to decode that signal. on the servo cable you have 3 wires +, -, and signal.
the signal goes into the input of the pic, and when the stick on the controller is pushed over 30% the indicators flash. this is what i have so far..
Input - Comes from receiver channel 2 steering. Determines if steering left or right.
If steering right - Output 1 goes high and flashes the leds.
If steering left - Output 2 goes high and flashes the leds.
If steering centered - no output sent.
I would like warning/hazard lights on here, but that can wait till i can resolve this.
I have very limited PIC experience and if anyone can help me, or show me how to do this i would appreciate it. I could just go and buy one, but then i wont get very far learning pic.
I have been looking all over the net to try and work this out and hit a brick wall.
Thanks for any help in advance
