RC Frequency Phase-Shift Calculation
Discussion in 'Homework Help' started by JDR04, Sep 17, 2012.
  1. JDR04
    Thread Starter Active Member
    May 5, 2011
    339
    Hi Folks, revisiting this one.
    I've attached the information I have on this question. What I don't understand is how the 50 and the 5 are derived in the formula. I think the 5 is derived from the fact that there are 5 wave forms in total with the circuit but am not sure.
    I can easily apply the formula as it is but would like to understand what I am doing and why.
    I think forum member WBahn would have an interest in this one as he previousely offered some wise advice to me.
    Your help will be appreciated and thanks again......JDR04
  2. ecesoul
    Sep 8, 2012
    8
    f=1/(2 x pi x R x C x sqrt(6))
    this become 50/RC..may be some rough practical approximation
    5k x 0.05microFarad = 5 x .05 ? might be wrong
  3. JDR04
    May 5, 2011
    339
    Might be,but I cant find any reference to it on the internet. My tutor is away as well so I cant get any help there either.Anyway thanks.-JDR04
  4. t_n_k
    Mar 6, 2009
    5,448
    783
    A detailed analysis of your oscillator is well established in the literature.
    It can be shown after a good deal of algebra that
    f_{osc}=\frac{1}{2\pi R C \sqrt{6+4\frac{R_C}{R}}} \  Hz
    If [as in your case] Rc=R then
    f_{osc}=\frac{1}{2\pi RC \sqrt{10}}=\frac{0.0503}{RC} \ Hz
    if R is in kΩ and C is in uF then
    f_{osc}=\frac{50.03}{RC} \ Hz
  5. JDR04
    May 5, 2011
    339
    Thanks t n k. It's all way above my level at the moment but I'll go through it bit by bit and see if I can make sense of it.
    Thanks for your time and input- JDR04
  6. JDR04
    May 5, 2011
    339
    Sorry, I meant to ask t n k. So the formula given in the text is a short cut in this situation. In any other type of phase shift frequency calculation the proper formula to use is the one supplied by you in you post.
    Am I understanding this properly so far? Thanks again - JDR04
