RC for Clock and clear
Discussion in 'The Projects Forum' started by simo_x, Jan 27, 2011.
  1. simo_x
    Dec 23, 2010
    200
    6
    I all, I have a circuit (I attacched it to the post). It's a dice, and I have a little question:
    If in the circuit I connect R5 (changing it from 1K to 10K) to the RC of R3 an C3, I can erase R4 and C4 from the circuit, correct?
    The purpose is to clear the MR in a shorter time than give a shot to CLK.
    I Think my idea is correct.. Could you confirm me that please??
    Thank you for your replies.
  2. simo_x
    Dec 23, 2010
    200
    6
    Well, I think my idea was bad, because capacitor charging time will always depend on R3*C3 without any delay on R5.
  3. ifixit
    Distinguished Member
    Nov 20, 2008
    639
    110
    • Why do you want to change it? Doesn't work the way it is?
    • D2 should be the other way around. Typo?
    • The Q1 clock enable circuit is only needed if the circuit is powered up with the push-button depressed. Right?
    • Could you use pin 4 of the 555 IC to keep the clock off until power is up?
    Regards,
    Ifixit
  4. simo_x
    Dec 23, 2010
    200
    6
    Just to simplify the circuit.. I thought it maybe works, but not, two Rc are needed.
    Yes, Q1 will give a PGT. Yes, I can use pin 4.
    EDIT: do you think is really bad working on the clock in this way?
    Thank for your reply.
  5. ifixit
    Nov 20, 2008
    639
    110
    Your way is okay, however, R5 and Q1 are not needed if pin 4 is used there-by saving some components. R4 and C1 would connect to pin 4.
    If you have a bread board of the circuit you could try it and see if you like how it works.
    Regards,
    Ifixit
  6. simo_x
    Dec 23, 2010
    200
    6
    Which way?
    One RC or two separates RC?
    I am already mounting assembling the circuit..
    Regards.
    Simo
