RC filter Ripple Calculation.
Discussion in 'General Electronics Chat' started by dileepchacko, Mar 21, 2011.
  1. dileepchacko
    Thread Starter Active Member
    May 13, 2008
    102
    Dear All
    How to calculate the ripple voltage of the RC filter. The Input signal is a Square wave signal. Thanks
    Regards
    DileepChacko
  2. t_n_k
    Mar 6, 2009
    5,448
    783
    There's probably no simple rule you can apply. For instance if the RC time constant is very small (<1/5 of T/2) compared with the half period of the square wave cycle then the ripple will be the same as the peak-to-peak value of the square wave. After 5 time constants any transient term in the analysis will have 'vanished'.
    For values of RC say >= 1/3 of T/2 (where T= waveform period) then you could come up with a ripple value which is a function of the peak-to-peak input voltage, RC and waveform period T.
  3. t_n_k
    Mar 6, 2009
    5,448
    783
    For the latter case I would use the following relationship ...
    V_{ripple}=(2V_{max}) \frac{(1-\epsilon^{-\frac{T}{2RC}})}{(1+\epsilon^{-\frac{T}{2RC}})}
    Where 2*Vmax is the peak-to-peak value of the square wave input.
    On reflection I guess this holds for all conditions. If the exponential terms vanish then the ripple is the same as the input.
  4. dileepchacko
    May 13, 2008
    102
    Thank you very much for this information, Is the ripple voltage depends on the load current of the circuit. I think the ripple voltage will increase, when the load current increases. Thanks.
  5. russ_hensel
    Distinguished Member
    Jan 11, 2009
    820
    47
    The math is not too hard using Q = CV and ohms law ( and calculus ). If that is too much why not simulate with LTSpice ( free ).
  6. t_n_k
    Mar 6, 2009
    5,448
    783
    Depends on what you mean by load current.
    Do you mean adding a load resistance across the capacitor or reducing the resistance value?
    The outcome will be different according to which of the two cases you mean.
