Good to see you Jony. As always your answer is a reason for me to study.If the load resistance for the left circuit is equal to R2 and input signal source will have a low resistance, then yes, the circuit are the same.
http://forum.allaboutcircuits.com/threads/resistor-role-in-a-high-pass-filter.47449/#post-312336
Hi,View attachment 105852
In the image there is on the left a high pass filter. What I want to ask is if the left circuit is the same with the right circuit.
No, I meant R2.I assume you meant "..load resistance for the left circuit is equal to R1", or not?
Externally ? No, we can find Zin in data sheetAnd i think that TDA7052 input impedance is set only externally (no info about input resistance in the topology og the IC) as in the next image:
Thanks, i like that you define the meaning of the word circuit and you count your sayings. Its the first time that i understand the word "circuit".Hi,
To be perfectly clear, neither diagram is a circuit. A circuit is a connection of elements that form a complete loop where current flows.
C1 (470nF) together with Rload (20kΩ for TDA7052) form a coupling circuit or a high pass filter with the corner frequency equal to Fc ≈ 0.16/(RC) ≈ 17Hz . and Rs= 5kΩ prevent the input from "floating".I now try to understand when and how
As i can get, if i would like the left RC connection to act same as the right RC connection and to be a high pass filter in a circuit, we want input signal source to have low resistance compared with r1 not to have attenuation of the signal in the sources' output and if the load resistance of the left circuit is equal to r2 (having c1=c2 uF) we will have the same frequency dependent voltage divider in both RC connections.If the load resistance for the left circuit is equal to R2 and input signal source will have a low resistance, then yes, the circuit are the same.
Yes, you are right.And expressing my question better, the left circuit it is not and it can not be a frequency dependent voltage divider as it is. It shall have a resistor path to ground to be one. Am i right?
Exactly.As i can get, if i would like the left RC connection to act same as the right RC connection and to be a high pass filter in a circuit, we want input signal source to have low resistance compared with r1 not to have attenuation of the signal in the sources' output and if the load resistance of the left circuit is equal to r2 (having c1=c2 uF) we will have the same frequency dependent voltage divider in both RC connections.
I wanted to know if there is a possibility the left circuit to be a filter, and so far the answer is yes. I now try to understand when and how.
Oh yes, i was wondering about this. We still some attention to the cut off frequency but what do we substitute in f=1/2pRC equation for R if we have only a coupling capacitor in the signals path? Or the paths around the coupling capacitor will always have a dc resistor path to ground or a load?2. The coupling circuit (or just coupling capacitor) is used mainly to remove the DC content in the signal, and not as strict on the filtering action although some attention is still payed to the cutoff frequency.
Yes it was really a general question of me, trying to understand if there was any possibility for this circuit to be a frequency filter. Jony covered about these two RC connections and you gave me a more general enlightenment about capacitors ac use.Hello again,
The main problem with the first circuit though is that we dont know what the load is, but most likely it is either used as a regular high pass filter or a coupling circuit.
Hello again,Oh yes, i was wondering about this. We still some attention to the cut off frequency but what do we substitute in f=1/2pRC equation for R if we have only a coupling capacitor in the signals path? Or the paths around the coupling capacitor will always have a dc resistor path to ground or a load?
by Jeff Child
by Jake Hertz
by Jake Hertz
by Aaron Carman
