I am a new hobbyist and I have a question which has conflicting answers online. I'm currently learning about rc timing circuits- more specifically- using a resistor/capacitor network to switch on a transistor after a certain time period. Charging and placing the capacitor in parallel with the base of the transistor is clear, but I am having trouble understanding the branch current calculations. When the switch is closed, I know caps act as a short immediately until charge and voltage build. What I don't understand is why I am taught by some that current takes every path available based on ohms law, while a reputable lecturer says that the initial 'short' from a capacitor will divert ALL current (even from a branch in parallel) until voltage builds. Can anyone help clear up how current behaves in this situation? Thank you.
