RC car Hooking LEDs in series? +knightrider lights?
Discussion in 'General Electronics Chat' started by stanman11, Nov 24, 2011.
  1. stanman11
    Nov 23, 2010
    230
    I gutted out an rc 4x4 and im swaping the electronics and theres an extra power output and I want to use that to hook up 4 LED lights.
    My question is how do I connect LEds in series with out losing power?
    Do I place something in between the LEDS?
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Hello Stanman,
    You didn't say what voltage is available, nor what the specifications are of your LEDs.
    We need to know what the typical Vf (forward voltage) is for your LEDs at their rated current.
    We also need to know what voltage is available at your "extra power output".
    If you want a "night rider" type of effect, you will need to buy a couple of ICs and build a circuit.
  3. stanman11
    Nov 23, 2010
    230
    Im not sure what the output is. I dont have a Multi meter here. Left it outside in the rain.
    The LEDS Im not sure either as the were on a different rc car.
    I was going to run a resistor regardless.
    I'm using a 9.6v that runs the motors and electronics.
    they seem to lose brightness being connected in series normally though
  4. Wendy
    Mar 24, 2008
    20,772
    2,540
    We also need a schematic of what you are trying to. You can only have 2 blue LEDs per chain with 9.6V, and that is assuming you have the full voltage. LEDs are must have resistors.
    A schematic sure would be nice.
  5. stanman11
    Nov 23, 2010
    230
    All Im trying to do is connect 2 white and 2 red LEDs on an already built circuit board from an rc car
  6. Wendy
    Mar 24, 2008
    20,772
    2,540
    White and blue are basically the same kind. Typically they drop 3.6 volts. Are all these LEDs in series together, or just the two?
  7. stanman11
    Nov 23, 2010
    230
    I took the electronics out of a tyco typhoon hovercraft.
    its has a 3 motor hook up.
    1 big motor 2 small motors.
    The big motor runs on its own once power is turned on.
    the other 2 motors only when you work the remote.
    The LEDS will replace motor 1.
  8. stanman11
    Nov 23, 2010
    230
    I cant tell but it looks like this on the original board.
    REAR Lights yellow yellow black blck are the wires and it connects as:::
    yellow to yellow to board:: black to black to board
    FRONT LEDS RED and GREEM
    RED connects nect to the rear yeally.
    ok screw this give me 15 min to gear up and take the board out of its water proffing inhousment
    OK IT DOESNT OPEN
    They seem to connect side by side but not sure if they actually connect together.
    I doubt they connect together.
    there has to be a power amp or mosfet chip in between some where
  9. Wendy
    Mar 24, 2008
    20,772
    2,540
    If you are trying to run them all together you are missing some key information about LEDs. Blue = 3.6V Red = 2.5V (Numbers are approximations)
    3.6V + 3.6 + 2.5V + 2.5V = you get the idea.
    LEDs, 555s, Flashers, and Light Chasers
  10. Wendy
    Mar 24, 2008
    20,772
    2,540
    Wait, are you replacing existing LEDs with different colors? LED color affects their dropping voltage.
  11. stanman11
    Nov 23, 2010
    230
    no Im simply switching boards. but instead of 2 channels connecting leds I need to use 1 channel because. The LEDS came off the board im taking out
  12. stanman11
    Nov 23, 2010
    230
    I got everything hooked up and working except for the LEDS But I ran into a problem.
    I had to take the on switch off the board because it was causing clearance issues.
    I soldered and external one on but its not working maybe this will work or not?
    ok it goes from:
    battery +to board
    B - to onbaord switch.
    New switch
    Batter to board
    B- to where the switch was. But the old switch is 3 prong
    So one proing is not hooked up.
    If I connect that extra prong to ground on the board will it work?
    ok that worked im good to go
  13. stanman11
    Nov 23, 2010
    230
  14. Wendy
    Mar 24, 2008
    20,772
    2,540
    Show us the lights, the other you seem to have down.
