RC Bandpass transfer function
Discussion in 'Homework Help' started by fireface, Apr 21, 2014.
  1. fireface
    Apr 21, 2014
    I'm having trouble getting the right transfer function for this using the OC and SC method for the time constants and getting the poles.
    Am I doing this right ...
    Open circuit
    1/s1 = (R1+R2)*C1
    1/s2 = C2*R2
    1/s3 = (R2+R3+R4)*C3
    1/s4 = C4*R4
    Short circuit
    1/s5 = R1*C1
    1/s6 = (R1||R2 +R3)*C2
    1/s7 = R3*C3
    1/s8 = R3||R4 *C4
    Where do I go after this?
  2. shteii01
    Feb 19, 2010
    3,516
    515
    Is this in terms of jw or s?
  3. fireface
    Apr 21, 2014
    's'... i think. sorry, been a long time
    s = jw?
    Did I calculate the poles?
    When I run it through multisim with the given values I get a pole at 500 rads/s. In my calcs I'm getting two SC poles at 1000 rads/sec and one OC at 333 rads/s. Is the combining effect giving me a corner frequency at 500 or am I just making things up?
  4. shteii01
    Feb 19, 2010
    3,516
    515
    Replace the capacitors with their impedance [Zc=1/(sC)=1/(jwC)]. Then use node voltage or mesh current method to get Vout in terms of Vin, so you will have Vout=(something)*Vin. Then carry Vin to the left side of the equal sign so you will have:
    Vout/Vin=(something)=Transfer Function=H(s)=H(jw)
    Done!
  5. WBahn
    Mar 31, 2012
    18,089
    4,917
    Are you trying to do an analysis based on a dominant-pole assumption?
  6. fireface
    Apr 21, 2014
    ^Yes
    Indeed approximating the poles and cutoff frequency. So the dominant pole is the smallest for high pass and the opposite for low pass?
