rating of transformers
Discussion in 'General Electronics Chat' started by gpvnayak, May 28, 2009.
  1. gpvnayak
    Jan 7, 2009
    what does the rating of a transformer typically contain?like, input power etc,.
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Step down low voltage transformers are rated by input voltage, output voltage, and output current. The manufacturer may also list insulation resistance and things of that nature.
    Look up a transformer and see how it is rated.
  3. gpvnayak
    Jan 7, 2009
    well the main thing is, I forgot about calculating current in short circuit test of a transformer.:confused:
    I have my practical exams tomorrow.I remember of finding the maximum current through the primary and accordingly varying applied voltage using the autotransformer. But I forgot how I calculated the value of that current.
    So i thought it may be given in the rating.
  4. PRS
    Aug 24, 2008
    989
    35
    I have a typical xformer in front of me. One side has two smallish wires and says PRI 120 V 60 Hz. The other side has three larger wires and says SEC 1.2A 6.3-0-6.3
    Sometimes, rather than giving you the secondary amperage outright it might give you the KVA of the secondary in which case you divide the power by the voltage at the secondary to get the maximum secondary current.
