1. The problem
A coil has self inductance L of 2 Henrys, and a resistance R of 100 Ohms. A DC supply voltage E of 100 volts is applied to the coil.
Show graphically the approximate rate at which the current increases at the moment of switching on (t=0) and after 10ms.
Confirm your results by differentiation.
2. Relevant equations
Instantaneous current: i=(E/R)(1-e^-Rt/L)
Slope of a tangent: y2-y1/x2-x1
di/dt: i(b)-i(a)/t(b)-t(a)
3. What I have done so far any my question (s)
Sorry guys, would not normally ask for help but I am stuck here and we have broken up for Xmas so I cannot ask anyone at the college I go to. Anyway if someone could have a quick look over this and point me in the right direction I would appreciate it.
* I worked out the time constant to be L/R = 20ms
* I worked out the maximum circuit current to be E/R = 1A
* I created an exponential growth curve showing the inductor current as a function of time using the instantaneous current equation above and taking points at every ms to 15ms then every 5 to 45ms (to show at least 2 time constants on the curve)
* Using the curve I plotted a tangent line across the point at 10ms. I took two points and used the slope equation y2-y1/x2-x1 to calculate the approximate slope at 10ms (30.8mA/s)
* I took point A at 10ms and point B at 15ms. I took the co-ordinates for A & B and worked out the average rate of current change between the two points as di/dt = 26.8mAs. I then moved B closer to A and re-calculated. I did this for lesser and lesser values of B and created a table. As B approached A I could confidently predict through di/dt that that A would equal 30mA/s at the point of 10ms.
My questions....
1) Can I assume that the simple operation of dy/dx above is enough in regards to differentiation to confirm the graphical approximation I made before it? Or am I looking for another method? (Relating to the 'confirm your results by differentiation' comment in the question)
2) Its asks for the rate of change of current at t=0. I am aware that there is no current through the inductor at t=0 due to the inductor opposing the current change (back emf etc) but there IS a current rate of change at t=0 and it can be calculated as: initial di/dt = E/L Amps. If I use this I get 50A/s as an initial current rate of change. How can this be shown graphically on the growth curve and is the above initial di/dt equation enough to satisfy the 'confirm by differentiation' statement in the question?
Thanks in advance.
Simon
My questions....
Thanks in advance.
Simon
