rascal mobility scooter 260 LE
Discussion in 'General Electronics Chat' started by cath, Aug 12, 2011.
  1. cath
    Aug 12, 2011
    12
    HI. I am looking for a electric circuit for a rascal mob scooter 260 LE. can anyone help. thanks. I would be grateful for any info a.s.a.p. thanks.
  2. debe
    Sep 21, 2010
    955
    185
    You will be lucky to find a circuit for a mobility scooter. Only options are replacement boards, or if you can try & fix it with out circuit diagrams. You havent given any reasons why you need it or whats wrong?
    cath likes this.
  3. iONic
    Nov 16, 2007
    1,422
    68
    cath,
    I'm going to reiterate what debe just said. Anything having to do with medical equipment is a very propitiatory and "closed-lipped" group. Schematics are impossible to get your hands on unless you know someone inside the business and they would be risking their job by offering it to you.
    Describe your needs and we can offer what assistance we can.
    cath likes this.
  4. cath
    Aug 12, 2011
    12
    PROBLEMS. 1. No drive.
    2. Control box replaced with new. 3.wig wag control replaced new. Wheels will drive when 12v is applied direct. Wireing seems ok. Can you suggest possible test. Thanks for the info so far.
  5. iONic
    Nov 16, 2007
    1,422
    68
    Does this scooter require 24V?
    Describe what happens when you try to run the scooter? Does it make any noise? Any relay sounds? Have you tried a different
    set of batteries? Are you sure the brake lever is in the correct position for operation, if not the scooter will just sit there doing nothing.
    cath likes this.
  6. cath
    Aug 12, 2011
    12
    The scooter requires 12v. when i try to run it there is no noise. no relay sounds. the batteries are new. The lights, horn, bleepers, all work. just not getting power? the brake lever is in correct position. Motor operates & electric brake is released when 12v is applied direct to motor.
  7. iONic
    Nov 16, 2007
    1,422
    68
    O.K. so power goes to the controller box which distributes power and drive signalling to the panel on your handle bars everything there works except the accelerator pot(the forward/reverse control) Yes?
    That pot or hall-effects-sensor returns a signal to the controller box and tell the motor to go and what direction.
    Did you assure all connector were snug?
    Do you mean that you are connecting the battery directly to the motor, making it run or that the motor runs and the wheels do not turn when connected up in the normal way?
    If the former, then the controller is not getting a signal from the pot, or a sensor that allows or disallows the scooter to run is bad or not being made.
    Or something else in the controller box itself.
    How did the problem surface...any progression in symptoms?
    cath likes this.
  8. debe
    Sep 21, 2010
    955
    185
    Generaly it helps to post good sharp pictures of both sides of any circuit boards & parts, otherwise were only guessing at what you are actualy working on. Especialy as there are no circuits avalable.
    cath likes this.
  9. cath
    Aug 12, 2011
    12
    The scooter stopped suddenly. Then it went forward then reverse rapidly. Then lost drive power. I have new batteries, I have replaced the wig wag controler, & the electric control box. Checked all the wireing, Checked the free wheel brake at the rear. All the lights work. Just no drive?
  10. cath
    Aug 12, 2011
    12
    Only wireing circuit is required. The printed circuit as been replaced new in the control box.
  11. iONic
    Nov 16, 2007
    1,422
    68
    Fuses O.K.?
  12. cath
    Aug 12, 2011
    12
    yes all fuses checked & ok?
  13. tom66
    May 9, 2009
    2,613
    214
    Any voltage at all appearing across the motor when the scooter is commanded to move forward?
    Can we have a pic of the board... I am thinking a bad MOSFET or diode somewhere and I need to get bearings on its architecture.
  14. cath
    Aug 12, 2011
    12
    It is a brand new control box. There is no voltage across the motor when commanded to move forward.
  15. tom66
    May 9, 2009
    2,613
    214
    Control box = motor driver?
  16. debe
    Sep 21, 2010
    955
    185
    The bit "Then it went foreward then reverse rapidly. Then lost drive power" Could very well be the point at which the new board has been damaged. Are the motors using a H bridge or relays to drive the motors Fwd/Rev? The only way you are going to get a circuit is draw it up your self.
  17. cath
    Aug 12, 2011
    12
    The control box was replaced after it lost drive. dont no if the H bridge or relays drive the motors Fwd/rev? a bit to technical for me?
  18. debe
    Sep 21, 2010
    955
    185
    Thats the reason for pictures of both sides of the circuit board. otherwise we have no idea what we are dealing with. Getting very late for me in this part of the world.
    cath likes this.
  19. cath
    Aug 12, 2011
    12
    Thankyou for all your info so far.
  20. cath
    Aug 12, 2011
    12
    Yes thats right.
