Paul,
I can tell you the electrode is positive and the voltage differential is right @ 80vdc on high. The Rocklinizer power supply circuit is a little more complex as it can control the depositing of tungsten carbide to 10 thousandths of an inch. Since your burning away a broken tap or bolt that would be over kill. Total current draw is 8 amp @120vac 1 amp is for the cooling fan motor. Edm fluid has me doing research, the viscosity and flash point, it all seems flammable!
