Rapid fire mouse button
Discussion in 'The Projects Forum' started by humanoid73, Mar 29, 2015.
  1. humanoid73
    Mar 29, 2015
    5
    Hello All, I'm new and I was hoping you all could help me... I was looking at this thread:
    http://forum.allaboutcircuits.com/threads/rapid-fire-mouse-button.15800/
    I put the mouse together using:
    555 ic timer,
    8 pin ic socket,
    1kOhm resistor,
    10kOhm resistor,
    4.7uf capacitor,
    small N/O switch
    Set it up like the figure and took pin 4 to Vcc....It works but I wanted to get about 12-15 clicks per sec (720-900 clicks per min)....The problem is I'm getting only 1.5 clicks per sec (90 clicks per min)....What do I need to do to increase my frequency?
    Thanks in advance!
  2. Dodgydave
    Jun 22, 2012
    5,154
    772
    use a 470nf capacitor,OR replace the 10K for a 1K resistor, that will increase the frequency by 10.
  3. humanoid73
    Mar 29, 2015
    5
    So if I replace the 10k with a 1k, I would have 2 - 1k resisters, one going from the 2 pin to 7 pin and the other 1k going from the 7 pin to the 8 pin. Is this correct?
  4. Dodgydave
    Jun 22, 2012
    5,154
    772
    yes, or replace the capacitor for a 470nF.
  5. humanoid73
    Mar 29, 2015
    5
    Cool I did it Thx Dodgydave!!
    got 10 clicks per second or 600 clicks per min....How can I get where I want to be 720-900?
  6. Dodgydave
    Jun 22, 2012
    5,154
    772
    need to put a variable resistor instead of the 1k resistor with a 330 ohms in series from pins 6,7.
    OR replace the cap for a 470nF, puta 10 k variable resistor between pin 6,7
  7. humanoid73
    Mar 29, 2015
    5
    ok thx a lot bud
  8. humanoid73
    Mar 29, 2015
    5
    Does it matter if I solder a resister from pins 2 to 7 vise pins 6 to 7? Note there is a jumper wire from pin 2 t0 6. Thx in advance!
  9. Dodgydave
    Jun 22, 2012
    5,154
    772
    no, its ok
