rapid DC current reversing
Discussion in 'The Projects Forum' started by doug leese, Feb 19, 2011.
  1. doug leese
    Feb 19, 2011
    Hello, I really need a way to reverse the polarity of a solenoid, changing the current seems like the best way...but doing this rapidly, with control is the objective, (rapid means 50 to 150 time per second) therefore making "North" into "South"
    Thank you ahead, to ANYONE smart enough to figure this out, Sincerely, D....
  2. blueroomelectronics
    Jul 22, 2007
    1,758
    98
    How large is the solenoid?
  3. hgmjr
    Jan 28, 2005
    9,030
    214
    Even better, can you provide a manufacturer's part number for your solenoid?
    hgmjr
  4. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Without knowing what solenoid you're dealing with, I'll suggest that an H-bridge with a chopper driver (to control current) will be required, and the driving voltage will likely have to be at least several times what the solenoid is rated for.
    Along with the solenoid manufacturer and part number, it would be very helpful to know what your intended application is. It may be far less complex to do something like use a motor with an elliptical cam, or offset crank pin.
  5. KMoffett
    Dec 19, 2007
    2,584
    234
    doug,
    Reversing the polarity of the standard solenoid will not change the direction of motion from push to pull...if that's what you are trying to do. Either polarity will pull the core.
    Ken
  6. bribri
    Member
    Feb 20, 2011
    133
    5
    so you want to make some kind of 'alternating current'?
