Rapid Cooler
Discussion in 'Off-Topic' started by 4beowulf7, Jul 26, 2015.
  1. 4beowulf7
    Jul 25, 2015
    20
    5
    Hello everyone!
    I was thinking on the problem of Rapid Cooling and I like to share my findings with you.
    Greetings
  2. tcmtech
    Nov 4, 2013
    2,107
    1,747
    No.
  3. Lestraveled
    May 19, 2014
    1,957
    1,217
    +1 on the NO.
  4. Brownout
    Jan 10, 2012
    2,375
    998
    You need so show the math that proves your theory.
  5. #12
    Nov 30, 2010
    16,665
    7,310
    Not a chance.
    State certified to design heating and cooling equipment up to 1/2 million BTUs per hour since 1985.
    Simply put, you can't destroy heat, you move it. If loading a lot of electrons on a capacitor made it hot, cooling the capacitor and then removing a lot of electrons would make it cooler than it was in the first place. If this had any chance of working, some air conditioners or refrigerators would have been made out of capacitors sometime in the last century. This concept was not overlooked, it was eliminated because it won't work.
    JoeJester and killivolt like this.
  6. Brownout
    Jan 10, 2012
    2,375
    998
    Actually, such a device exists, though it doesn't use or require high voltage, nor does it use kinectic energy of free electrons. But is does use nothing more than a DC current and semiconductor junctions.
    https://en.wikipedia.org/wiki/Thermoelectric_cooling
    Theoretically, a surface with free electrons can cool via radiation. If there was a way to enhance this mode of cooling, then you might have something....
  7. #12
    Nov 30, 2010
    16,665
    7,310
    I feel it is appropriate to mention that a Peltier device is not a capacitor and does not operate on the principle of reversing the polarity of the charge to remove heat laden electrons.
  8. Brownout
    Jan 10, 2012
    2,375
    998
    Course, I already pointed those things out in my post. It does however use electron drift to cool. Whether or not electrons can carry the heat that they absorb is above my pay grade.
  9. wayneh
    Sep 9, 2010
    12,374
    3,226
    Another NO vote.
