range question
Discussion in 'Math' started by braddy, Oct 7, 2005.
  1. braddy
    Dec 29, 2004
    83
    Hi
    please I need some help to dtermine the range of the following function:
    f(x,y)=(e^x - e^y)/ (e^x +e^y)
    the domain is all the real for x and y.
    I know that the answer for the range is [-1,1] but I do not know how they found it.
    Thank you
    Braddy
  2. haditya
    Jan 19, 2004
    220
    one easy way to find this out would be to find maxima -minima using derivatives
    since its a a function of two independent variables
    the following conditions are to be satisfied:-
    ∂ f/ ∂ x = 0
    ∂ f/ ∂ y = 0
    this will give you the pair of critical points(x,y) where optima may exist
    let r= ∂ ^2 f/ ∂x^2 ; s= ∂ ^2 f/ ∂y^2; t= ∂ ^2 f/ ∂x ∂ y;
    substituting each of the above critical points into the second order derivatives we check for the following conditions:
    1. rt-s*s <0 no maxima or minima
    2. rt-s*s > 0 => maxima if r<0; minima r>0
    3. rt-s*s = 0 => test is inconclusive and an alternate means must be established
    try attemptin a solution using this fact
  3. braddy
    Dec 29, 2004
    83
    I didi it it!
    Thanks a lot
    Braddy
  4. barrygale2003
    Oct 11, 2005
    Here is a simpler method:
    If x can be any number (positive or negative) then e^x varies between "0" (it can't actually reach zero, but can get as close as you like) and + infinity. Same for e^y of course.
    Let u=e^x and v=e^y. Then the fraction is (u-v)/(u+v), which is easier to think about.
    To get a feel for the fraction, look at some extreme cases :
    When u>>v (v is negligible by comparison with u) then the fraction becomes u/u which is +1.
    When u<<v (u is negligible by comparison with v) the fraction becomes -v/v which is -1.
    When u=v the fraction becomes 0/2u which is 0 (provided u is not zero).
    This suggests that the fraction varies between +1 and -1, but isn't conclusive - there might be some weird behaviour in between. We need a logical proof.
    Because u and v are both positive their sum (u+v) is always going to be bigger than their difference (u-v). So the fraction will always be "bottom heavy", ie less than 1 (ignoring the sign). It could only reach 1 if one of u or v is exactly zero, but that can't happen (e^x never reaches zero no matter how large and negative x is).
    What if both u and v were zero? Then we could have a problem to decide about the value of 0/0. Well, neither can reach zero, so there's no problem.
    So the fraction varies between (but never actually equals) +1 and -1.
