Random reboot MCU
Discussion in 'Embedded Systems and Microcontrollers' started by FroceMaster, Dec 6, 2015.
  1. FroceMaster
    Jan 28, 2012
    402
    Have this setup,
    And have these randoms reboots,
    Could be 2 weeks or even just 2 hours between.
    Have a feeling that it is do to the powersupply,
    Powersupply is a outlet from 220v to 5v USB where i have just taken the GND and 5v.
    When i turn on some lamps or other thing in the house it could reset.
    Should i put in some caps or ???
    and where. ?
  2. spinnaker
    Oct 29, 2009
    5,089
    1,185
  3. nerdegutta
    Dec 15, 2009
    2,568
    806
    Have you tried, just for the fun of it, power it from a PC's USB port? And then turn light on/off.
    I agree with @spinnaker that you need some caps.
    How much mA does your powersupply give?
  4. FroceMaster
    Jan 28, 2012
    402
    Power supply is 5v 800mA
    Dont think i use more than 50mA
    Will try to put a cap over the supply first
    What should i use ?
  5. nerdegutta
    Dec 15, 2009
    2,568
    806
    When I make powersupplies for microcontrollers, I'm using a LM7805 or LM78L05 regulator with a 0.1uF ceramic and 100uF electrolytic cap on both input and output. Close to the powerpin on the microcontroller, I put a 0.1uF ceramic.
  6. spinnaker
    Oct 29, 2009
    5,089
    1,185
    Read the article I posted. The cap needs to be on the pic not on the supply.
  7. FroceMaster
    Jan 28, 2012
    402
    i have now solder a 0,1uf ceramic cap over the pin 1 and 20 at the MCU.
    Give it a try.
  8. nerdegutta
    Dec 15, 2009
    2,568
    806
    If you have an oscilloscope, you could probably measure the USB supply when you turn lights off/on. I don't know if you'd get a reading with a DMM.
  9. Picbuster
    Member
    Dec 2, 2013
    391
    53
    problem: spikes
    solution: see attached
