Dave,
Ratch
It appears to me to be a distinction without a difference. I agreed before that Ohm's law is a statement about proportionality, specifically linear proportionality. That does not make it a definition of resistance.Quote:
Originally Posted by Ratch
Indeed that is true, and it should be straightforward. I never said otherwise. That does not differ from Ohm's law as I quoted from the two textbooks cited previously: The resistance of metallic conductor is the same no matter what applied voltage is used to measure it.
The two statements are different, even if the differences are subtle. Ohms Law is stated in Georg Ohm's own words, not an interpretation of Ohm's words like the textbooks you cite. If you read the above, Ohm's Law is merely a statement of proportionality derived through empirical studies.
R=V/I will always be correct anywhere on the diode V-I curve, because that is the definition of resistance. Three or more points are needed to determine linearity, and compliance with Ohm's law.Quote:
The textbook goes on to say that if the resistance is not linear, then it does not follow Ohm's law. Yet most people want to tie the definition of resistance to a material property. That is wrong, not because of any semantic differences, but because it is a misnomer. Will you come out and say that the professors who wrote those textbooks are wrong? Can you find a good college level physics textbook that says uneqivocally that Ohm's law is V=IE?
I will say it again, in Georg Ohm's own words, Ohm's Law is a statement of proportionality. With that in mind, take a diode which has a non-linear I-V characteristic across a wide voltage range and hence in your world never meets the conditions of Ohms Law (whatever definition you wish to apply); however the diode is locally ohmic, that is over a very small change in applied voltage the current is (effectively) directly proportional to this voltage - and at a fixed applied voltage, in the absence of other extenuating factors as outlined by Ohm, the steady current definition applies and the diode has a resistance that is defined by R = V/I. It is said to be locally ohmic because the I-V characteristic satisfies Ohms' statement of proportionality.
Ratch
