how to design 64x4 ram using 16x1 ram
WBahn Joined Mar 31, 2012 30,088 Nov 21, 2016 #3 Abu Tahir said: how to design 64x4 ram using 16x1 ram Click to expand... How would you design a 64x1 RAM? How would you design a 16x4 RAM?
WBahn Joined Mar 31, 2012 30,088 Nov 21, 2016 #4 MOD NOTE: Moved from Digital Circuit Design to Homework Help.
Kermit2 Joined Feb 5, 2010 4,162 Nov 21, 2016 #5 You should place them parallel with shared address bus lines but each with its own independent read and right line.
WBahn Joined Mar 31, 2012 30,088 Nov 21, 2016 #6 Kermit2 said: You should place them parallel with shared address bus lines but each with its own independent read and right line. Click to expand... But they can share the left lines? Interesting coincidence in that I made the same mistake last week and I think I've seen at least two other folks make it in that same time frame. Of course, it's an easy typo to make and we all have made it many times.
Kermit2 Joined Feb 5, 2010 4,162 Nov 21, 2016 #7 Does that make me not write? Or is it left to the reader to decide who's right?
Papabravo Joined Feb 24, 2006 21,228 Nov 21, 2016 #8 You can only read and write to an enabled chip. Each address will select four of the sixteen total chips to read from and write to.
