Raindrops keep falling through my differential equation
Discussion in 'Math' started by Drawoh, Aug 21, 2008.
  1. Drawoh
    Aug 21, 2008
    Greetings,
    given a laser beam of 0.5 mm in diameter, hitting a light sensitive target at 10 meters which will register a pulse as small as 1 uSec, what would the differential equation (*) for the number of times per second the beam will be cut during a normal rainstorm?
    *) I assume it would be a diff.eq, but am near clueless how to approach this.
    "Raindrops range from 1/100 inch (.0254 centimeter) to 1/4 inch (.635 centimeter) in diameter... Not including wind-driven rain, raindrops fall between 7 and 18 miles per hour (3 and 8 meters per second) in still air. The range in speed depends on the the size of the raindrop. Air friction breaks up raindrops when they exceed 18 miles per hour. "
    thanks much for any suggestions,
    Howard
    ________________________________
    references:
    http://www.weatherwizkids.com/Rain.htm
    http://ga.water.usgs.gov/edu/raindropshape.html
  2. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    Why would it be a differential equation? Wouldn't one just use drops per square meter per second and plug into an algebraic expression?
