railway project
Discussion in 'The Projects Forum' started by shweta sharma, Jul 25, 2013.
  1. shweta sharma
    Jul 25, 2013
    6
    i needed assistance for the project to stop the trains automatically on the same track 100 meters apart.
  2. new voodoo
    Jul 25, 2013
    5
    Do you mean hobby/toy trains? or real ones? I would assume the former because the latter would obviously be more of a question for railway engineers..but there are hundreds of possibilities I can think of..and im not that experienced.
    just a few offhand:
    -sensors: pressure, PIR, any number of types would tell you when theyre at the same pt ,etc
    -beam interruption: IR, laser, typical visible freq light, etc-whenever its interrupted you could stop the train, and if the beam is at one place going across both tracks..or two beams 100 meters apart in same line.
    you could google, say, pressure sensor or IR emitter, etc and easily find something. I saw an inexpensive exterior-purposed beam on sale at, I think, AllElectronics or electronicssurplus.
    shweta sharma likes this.
  3. MaxHeadRoom
    Jul 18, 2013
    10,835
    2,506
    I hope they ARE hobby units at 100m apart, not full size units heading toward each other! :eek:
    Some kind of radio or wireless detection method might work, I am assuming that it has to work on any track, not just a pre-assigned section?
    Max.
  4. mcgyvr
    Oct 15, 2009
    4,787
    973
    In the future please put a little more effort into constructing a complete and detailed question.
    How about 50m rubber bumpers attached to each train? :p
  5. kubeek
    Sep 20, 2005
    4,687
    805
    I think OP means that the trains should come no closer together than 100m, so the system should take speed and braking distance into account, so the rubber bumpers would need to be a bit longer :p
  6. MaxHeadRoom
    Jul 18, 2013
    10,835
    2,506
    If we were talking full size locomotive, 100m would in most cases, be out of the question, a lot depends on speed, grade, amount of cars/ loaded/unloaded, but the conservative average for a typical made up train could be around 1 mile stopping distance.
    Max.
  7. donpetru
    Nov 14, 2008
    186
    25
    I can help you but you must tell me more. I suppose it is a hobby project (built to scale). So we need to clarify several issues:
    - What voltage you connect train?
    - How you actually made ​​power supply train? You used the contact line or another method?
    If you want to keep a minimum distance between two trains then you can:
    - Monitor speed trains with a PC and an adjusted accordingly (you can program your PC to do this);
    - Control the movement of trains through the railway section control (this solution has several aspects that require modernization).
    So, back with more details.
  8. mcgyvr
    Oct 15, 2009
    4,787
    973
    Why? he never said anything about a "smooth" stop or anything about braking distance/train weight or passenger comforts :D
  9. mcgyvr
    Oct 15, 2009
    4,787
    973
  10. MaxHeadRoom
    Jul 18, 2013
    10,835
    2,506
    All the travelogues I have seen, most ride on the roof? :D
    Max.
  11. mcgyvr
    Oct 15, 2009
    4,787
    973
    exactly.. or handing off the side,etc..
  12. MaxHeadRoom
    Jul 18, 2013
    10,835
    2,506
    I guess we shouldn't jump to conclusions, it could be Pakistan? ;)
    I wonder if there is a governing body there that most countries have? US-AAR UK-ORR etc.
    Any equipment that is aimed at railway safety normally has to be approved?
    Max.
  13. blueroomelectronics
    Jul 22, 2007
    1,758
    98
    I love train travel but it's very underused here in Canada. In other countries it's the only way to get around and is outdated, overcapacity and somewhat hazardous.
    As to the OPs problems build a proper crossing or ramp overpass. Nobody is going to stop the trains every time something gets on the tracks, the trains have right of way.
    The big problem is often it's just not a priority in developing countries. Too much other stuff needs fixing first.
    And yes, it's an obvious student project, it's always railroad crossings, traffic lights or a UPS, once in a blue moon you'll get an elevator.
  14. shweta sharma
    Jul 25, 2013
    6
    hello. no tym for silly jokes.it was for a project purpose.i wanted to make a project automatic stopping the trains if bt chance 2 comes on the same track by irself by using rf technology.by the way i got hekp from indian railways.. its the largest network and the best..thank you all for your valuable assistance but no longer useful for me.
  15. MaxHeadRoom
    Jul 18, 2013
    10,835
    2,506
    There was no malice intended, just an attempt at light humour!
    As I mentioned, I would consider 100m non-practical unless this was shunting yard?
    Max.
  16. kubeek
    Sep 20, 2005
    4,687
    805
    I don´t know how you read the original post, but to me "project to stop the trains.. /snip/ ..100 meters apart" means that they will be stationary one hundred meters apart, not that they will start stopping at that distance.
  17. mcgyvr
    Oct 15, 2009
    4,787
    973
    Ok 51 meter rubber bumpers then :p
  18. Kermit2
    Feb 5, 2010
    3,847
    963
    GPS
    It can do what you want. With proper application it can keep trains, that are in communication with each other, running at even closer spacings.
  19. #12
    Nov 30, 2010
    16,665
    7,310
    Please don't do that just because you can. Everything has a likelihood of failure at some time or another, and train wrecks are very messy!:p
