Radio Transmitter design
Discussion in 'Wireless & RF Design' started by kayusbrown, Jan 13, 2009.
  1. kayusbrown
    Jan 13, 2009
    I need a comprehensive procedure in designing a commercial radio transmitter with total power of about 1KW.
  2. bertus
    Administrator
    Apr 5, 2008
    15,802
    2,387
  3. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    You're going to have to get a license from the FCC before you can power up the transmitter. They will have to pass on the design as well as granting you the license.
  4. garry.owens
    Member
    Dec 17, 2008
    17
    you have to explain what this is meent for what frequency you whant and that power do you intend to use valves but legally i need to know what the intended use of this power is before i can help any further that is a lot of power and can do a lot of harm to a lot of peple
  5. garry.owens
    Member
    Dec 17, 2008
    17
    you have to explain what this is meent for. what frequency you want. and that power do you intend to use valves. but legally i need to know what the intended use of this power is before i can help any further. that is a lot of power and can do a lot of harm to a lot of peple
  6. kayusbrown
    Jan 13, 2009
    I'm a final year student in a Polytechnic in Nigeria and I intend to design and construct a Transmitter for my final year project. It is not a neccessity that the total output power should be up to 1KW. All I need is a long range of transmission say about 5km. If the project is successful, a licence will be obtained from Nigeria Communications Comission befor it is put to use in the polytechnic.
  7. Wendy
    Mar 24, 2008
    20,772
    2,540
    Frequency and modulation scheme would be helpful.
  8. jj_alukkas
    Distinguished Member
    Jan 8, 2009
    751
    5
  9. bertus
    Administrator
    Apr 5, 2008
    15,802
    2,387
    In my PM I found this message:
    I think that 5 - 10 wats will be more than enough.
    For stability a crystal or PLL system will be OK.
    Greetings,
    Bertus
  10. KL7AJ
    Nov 4, 2008
    2,047
    295
    Actually in the U.S., it's 1500W :)
