Radio memory wire
Discussion in 'The Projects Forum' started by enbarnes357, Oct 7, 2013.
  1. enbarnes357
    Oct 7, 2013
    first let me say i am glad to be part of this forum, have a project i am working on and need some help, i have taken a in dash car dvd player and installed it on my tailgating cart what i am using is a 12dvc regulated switching power supply which gives me 12 volts. the problem i have having is keeping memory to my radio presets, so i installed a battery which after time has to be charged so i got to thinking what if i could install some type of relay,which would allow the 12vdc regulated power supply to power the memory wire and once i cut off the system the 12vdc battery will kick in does this sound possible?
  2. Alec_t
    Sep 17, 2013
    5,973
    1,135
    Forum rules don't allow posts about automobile projects.
  3. enbarnes357
    Oct 7, 2013
    ok but i wanted to know what type of circuit would i need to switch the radio memory from the 12vdc power supply to the 12vdc battery not about the radio.
  4. #12
    Nov 30, 2010
    16,703
    7,339
    This isn't a car modification in my opinion.
    A couple of 1N4001 to 1N4007 diodes should work, or just leave the memory wire powered by the battery all the time.
  5. GopherT
    Nov 23, 2012
    6,314
    4,031
    What does that rule have to do with the OP's question?
  6. adamclark
    Member
    Oct 4, 2013
    472
    6
    thats an easy fix with a standard spdt automotive relay.. ill draw you up a picture if this is what you need... and don't you get some hum through the power supply?
  7. enbarnes357
    Oct 7, 2013
    Thank you very much any help you can give me would be greatly appreciated as fir the hum I havent had any issues with noise
  8. DerStrom8
    Feb 20, 2011
    2,428
    1,329
    I agree, it's simply an external project using automobile parts. No rules against that! :)
  9. adamclark
    Member
    Oct 4, 2013
    472
    6
    one quick question before I draw it up for you,, how do you turn the power supply on? through a switch?
  10. adamclark
    Member
    Oct 4, 2013
    472
    6
    here is the picture I promised, you need a standard 20/30 amp spdt automotive relay(if it has 5 pins its spdt)... heres how it works,,, the 85 pin comes from the psu power switch to turn the relay on, the 86 pin is the ground for the relay, pins 87 and 87a are normally connected when the relay is off, and pin 30 is the 12v output from the psu. when the psu is off pins 87a and 87 are connected, when you turn the psu on the relay turns on connecting pin 30 with pin 87 letting the psu run the memory.. turn the psu off and the relay turns off letting the batt run the memory wire... hope this is what you needed....cheers
  11. adamclark
    Member
    Oct 4, 2013
    472
    6
    if you don't use a switch to turn the psu on,, you can use the 12v output from the psu (pin30) to do the same thing
  12. #12
    Nov 30, 2010
    16,703
    7,339
    That will work just as well as my diode idea.
  13. adamclark
    Member
    Oct 4, 2013
    472
    6
    yea I thought so,, this is what I do for a living,,, I forgot to mention to put a 10 amp fuse on pins 85 and 30 though.. always a good idea to fuse..
  14. #12
    Nov 30, 2010
    16,703
    7,339
    I would like to mention that diodes are cheaper than relays and don't eventually get contact resistance build-up.
    I also think the memory circuit takes very little current, does it?
  15. adamclark
    Member
    Oct 4, 2013
    472
    6
    no more than 2 amp. relays are about 6 bucks at the autoparts stores. if you use a quality weather resistant terminal, and don't turn it on and off 100 times a day the resistance build up shouldn't be a problem for 5 years.. I have relays on my boat that have been there for 5 years without any corrosion yet... but I like the diode idea.. I use diodes at work to isolate things, but its mainly ground feedback im isolating. Im just now starting to learn more about electronics and circuits and such so relays have been my main solution for a lot of things in the past..lol
    #12 likes this.
  16. enbarnes357
    Oct 7, 2013
    would like to thank everyone for their help, i will be trying this out today, as for how i turn on the psu it is thru a switch thanks.
  17. #12
    Nov 30, 2010
    16,703
    7,339
    If the memory circuit requires, "more than 2 amps", or, "no more than 2 amps" I called out the wrong diodes. You would need "3 amp" diodes like 1N5404 or STP3150RL.
