R5F212L4SNFP clock settings register
Discussion in 'Embedded Systems and Microcontrollers' started by Vindhyachal Takniki, Aug 17, 2016.
  1. Vindhyachal Takniki
    Nov 3, 2014
    357
    6
    1. I have written code for using on chip high speed oscillator for R5F212L4SNFP MCU for maximum 20Mhz speed.
    Is below settings & sequence ok?
    2. How many nop to be added to get clock stable. currently I have added 4.
    <code>
    void set_system_clock(void)
    /* Interrupt disable */
    asm("FCLR I");
    /* Protect off */
    prc0 = 1;
    /* cpu settings */
    cm02 = 0; /* Peripheral function clock does not stop in wait mode */
    cm05 = 1; /* XIN clock stops */
    cm06 = 0; /* CM16, CM17 enabled */
    cm10 = 0; /* Clock operates */
    cm11 = 1; /* On-chip feedback resistor disabled */
    cm13 = 0; /* Input ports P4_6, P4_7 */
    cm14 = 0; /* Low -speed on-chip oscillator on */
    cm15 = 1; /* XIN-XOUT drive capacity high */
    cm16 = 0; /* System clock division select bits; no division */
    cm17 = 0; /* System clock division select bits; no division */
    ocd0 = 0; /* Oscillation stop detection function disabled */
    ocd1 = 0; /* Oscillation stop detection interrupt disable */
    ocd2 = 1; /* Selects on-chip oscillator clock */
    ocd3 = 1; /* XIN clock stops */
    fra00 = 1; /* High-speed on-chip oscillator on */
    fra01 = 1; /* Selects high-speed on-chip oscillator */
    fra20 = 0; /* High-speed on-chip oscillator frequency sw itching bits, Divide-by-2 mode */
    fra21 = 0; /* High-speed on-chip oscillator frequency sw itching bits, Divide-by-2 mode */
    fra22 = 0; /* High-speed on-chip oscillator frequency sw itching bits, Divide-by-2 mode */
    /* let clock get stable */
    asm ( "nop" );
    asm ( "nop" );
    asm ( "nop" );
    asm ( "nop" );
    /* Protect on */
    prc0 = 0;
    /* Interrupt enabled */
    asm("FSET I");
    } /* functin ends here */
    </code>
