quoting posts
Discussion in 'Feedback and Suggestions' started by kubeek, May 22, 2015.
  1. kubeek
    Thread Starter AAC Fanatic!
    Sep 20, 2005
    4,687
    805
    Could we get an option, or even just set it for all, to disable the multi-quote functionality? It is quite annoying when you need to click three times to quote someone, instead of just once.
    Over at ETO which runs basically the same engine it works like this: You click the quote button, and the quoted post gets inserted at the cursor in the reply box below. You click another quote, another gets inserted right at the cursor.
    Here I have to click "quote", "insert quotes", and then "quote these messages" to do this, and that seems rather annoying and clumsy.
    atferrari likes this.
  2. atferrari
    Jan 6, 2004
    2,663
    783
    I second that.
  3. jrap
    Administrator
    Jun 25, 2006
    966
    202
    Hi @kubeek, I believe the Quote feature on ETO is the same as hitting the "Reply" button here. They have disabled the "+Quote" multi-quote feature and renamed "Reply" to "Quote".
  4. WBahn
    Mar 31, 2012
    18,083
    4,917
    Why do we need to disable a function?
    If you want do what you describe, just use a different function that does it, namely "Reply"?
  5. bertus
    Administrator
    Apr 5, 2008
    15,798
    2,384
    We could enable the multi quote and call the +quote "multi quote" and teh reply "direct quote".
    With "multi quote" you can quote parts of multiple posts and even from multiple threads.
    This can be handy when there is something relevant posted in an other thraed.
    This way we can have the best of the old and new features.
    Bertus
  6. Wendy
    Mar 24, 2008
    20,772
    2,540
    I'm still learning the features on this new software. So I watch and learn.
  7. bertus
    Administrator
    Apr 5, 2008
    15,798
    2,384
    Watch the following video on multi quote:
    Bertus
    elec_mech likes this.
