Quiz Review
Discussion in 'Homework Help' started by thakid87, Oct 27, 2009.
  1. thakid87
    Thread Starter Active Member
    May 23, 2009
    122
    Hey, all. The attached PDF shows the questions I had on my quiz earlier today.
    On #1, all resistors are 3.3k.
    #2, Current at R1 = 2mA at R2 = 1.14mA at R3 = 0.42mA
    The following are my answers:
    1A. Current through R2 = 5.05mA
    1B. Total current is 10.1mA
    2A.
    2B. 2.58mA @ R4
    3. RT = 2.02kΩ
    4A. Total current 939mA
    4B. Current @ R1 = 273mA
    Current @ R2 = 333mA
    Current @ R3 = 333mA
    5. Current @ R1 = 1.001mA
    Current @ R2 = 2.001mA
    I didn't have enough time to get the values of the resistors on question #2.
    BTW, that's my professor's handwriting...
    Thanks in advance.
  2. ELECTRONERD
    May 26, 2009
    1,146
    16
    Wrong.
    First, you should add up all the parallel resistors (and they are all parallel). So \frac{1}{3.3k}+\frac{1}{3.3k}+\frac{1k}{3.3k}=1.1k
    Now to find the total current, \frac{50V}{1.1k}=45.5mA
    For each individual resistor, \frac{50V}{3.3k}=15.2mA.
    So add them up just to make sure the total current is correct: 15.2mA+15.2mA+15.2mA=45.6mA. That is indeed correct. So each resistor has 15.2mA of current flow and the total current is about 45.5mA.
  3. thakid87
    May 23, 2009
    122
    So, all three resistors are in parallel? I don't see that.
  4. Boo
    Member
    Oct 27, 2009
    40
    Scratch that, they are.
    Look at it this way, they share a common node at each end :)
  5. ELECTRONERD
    May 26, 2009
    1,146
    16
    Yes indeed, they are. Take a look at R1 and R2, just move R1 so it's completely vertical and you have both resistors in parallel. Furthermore, move R3 so it's vertical too and you'll see that all three resistors are in parallel. Understand?
  6. thakid87
    May 23, 2009
    122
    Let me take another look...
  7. ELECTRONERD
    May 26, 2009
    1,146
    16
    For your second quiz question, what current values are listed for R2 and R3? It's difficult to read them, so could you list them on a post?
    Austin
  8. thakid87
    May 23, 2009
    122
    I have just noticed how they are all in parallel....
    This is great...
    And the currents are listed on my first post.
    I total = 5mA
    I @ R1 = 2mA
    I @ R2 = 1.14mA
    I @ R3 = 0.42mA
  9. JoeJester
    Apr 26, 2005
    3,400
    1,218
    Now that you agree the resistors are connected parallel, don't you agree your original calculations might need revising?
  10. thakid87
    May 23, 2009
    122
    That was to ELECTRONERD in reference to the second question on the quiz.
    I have a feeling I bombed this quiz.
    Thanks for the help guys.
  11. ELECTRONERD
    May 26, 2009
    1,146
    16
    Ok, I think you made a mistake listing the total current. You say the total current is 5mA but in the PDF it has 50mA total going into the circuit. I'm assuming it is 5mA based on each individual current values at each resistor.
    First you add them up, 2mA + 1.14mA + 0.42mA = 3.56mA So obviously you would subtract the current through each resistor which we summed up to be 3.56mA from the total current to find the current value for R4. 5mA - 3.56mA = 1.44mA Therefore we can assume that the current through R4 is 1.44mA and that all the currents through each resistor sum up to the total current (5mA). 2mA + 1.14mA + 0.42mA + 1.44mA = 5mA That is true and the current through R4 is indeed 1.44mA.
    Do you see how this is wrong? Also, I'm unsure what they are asking for for 2a. Do they actually want the value of R4 in ohms? If they do, it's interesting that they didn't have you find the current through R4 before finding the actual resistor value.
