Quiz question - Thevenin and Norton Circuits.
Discussion in 'Homework Help' started by J.live, Oct 12, 2010.
  1. J.live
    Sep 10, 2010
    35
    Which of it is true
    Edit
    I am not sure how to do this one.
    15 ll 10 = 6
    10 ll 10 = 5
    RL= 11 ? I know this is wrong.
    Va = 30 x ( 10 / 10 +5 )= 2
    Va' = 30 x ( 10 / 10 +10 )= ?
    I am having trouble splitting the RL and Vth
    I am totally lost on this one.
    P.S sorry for not showing work before .
  2. ELECTRONERD
    May 26, 2009
    1,146
    16
    What do you mean which of it is true? Is there a question that came with the problem? Provide your work first, before you expect us to do it for you.
  3. J.live
    Sep 10, 2010
    35
    Yeah, reposted the question.
  4. Georacer
    Nov 25, 2009
    5,151
    1,266
    The circuit doesn't give you enough information to calculate R_L and it doesn't want you to either.
    You need to convert the circuit to its Thevenin equivalent. Read here for info: http://www.allaboutcircuits.com/vol_1/chpt_10/8.html
    What you also need to know is that in order to have maximum power transfer, the R_{th} must be equal to R_L.
  5. JoeJester
    Apr 26, 2005
    3,402
    1,223
    Attached is one way ....
    After you do the calculations, test each answer till you find which one is true, if any.
