Quiz help
Discussion in 'Homework Help' started by jaymo3141, Feb 17, 2014.
  1. jaymo3141
    Feb 16, 2014
    8
    The steps I have done so far are:
    1. Found Vx by ignoring the 4 Vx and doing a mesh on the loop which gives me 0.5 for Vx
    2. Short circuit Voc
    after this i'm stuck. Can someone solve this. My friend got -15v but i'm not sure if he's right. Either way i have to submit this quiz today so if -15v is wrong then i'm getting this question wrong. It would be helpful if someone walked me through the solution though. Thanks.
  2. tshuck
    Oct 18, 2012
    3,531
    675
    You can also solve it by realizing no current flows through the dependent source, so Vx is a voltage divider output. Then the dependent source makes its negative side 4*Vx lower than the voltage at Vx.
  3. shteii01
    Feb 19, 2010
    3,500
    511
    Do you mean: Vx=4Vx+Voc
    So Voc=Vx-4Vx
    Is that what you mean?
  4. shteii01
    Feb 19, 2010
    3,500
    511
    According to my math skills your Vx is wrong.
  5. tshuck
    Oct 18, 2012
    3,531
    675
    I am applying the definition of a voltage source: its positive side is X volts above its negative side, regardless of whether X is a constant or a function.
    Since this doesn't load Vx (as there is no current through the dependent source), you can conclude that Voc = Vx - 4Vx because the voltage at the dependent source's positive side is the dependent variable. Since the dependent voltage source is 4Vx volts, its lower side will be 4Vx volts lower than the positive side. Same answer, but different approach.
  6. alfacliff
    Dec 13, 2013
    2,449
    428
    5 volts. simple voltage devider. didnt even need a calulator.
  7. shteii01
    Feb 19, 2010
    3,500
    511
    Is that your answer to Voc or Vx?
  8. alfacliff
    Dec 13, 2013
    2,449
    428
    voc. this durn thing wants a longer response.
  9. shteii01
    Feb 19, 2010
    3,500
    511
    I got -15 V for Voc.
  10. studiot
    Nov 9, 2007
    5,005
    515
    The dependent voltage source is open circuit therefore passes no current in this circuit, as tshuck says.
    So the 20k and 50k resistors form a simple potential divider, which gives Vx.
    The voltage of the dependent source is stated to be 4Vx so its negative end is 20 volts below the node (+5) to which it is coupled.
    I make Vx = +5 volts and Voc = -15 volts.
    So now you have tshuck's mathematical method and a physical circuit explanation to compare.
  11. WBahn
    Mar 31, 2012
    18,087
    4,917
    In other words, you couldn't solve it and so you just copied your friend's answer and submitted it as your own.
    What's your school's policy on academic integrity?
  12. jaymo3141
    Feb 16, 2014
    8
    Thank you everyone. I made a stupid math error. Appreciate your help
