Quick Thevinin Question
Discussion in 'Homework Help' started by Digit0001, May 31, 2011.
  1. Digit0001
    Mar 28, 2010
    89
    Hi
    Can someone tell me how would i do this question
    I have tried to use a nodal analysis but still incorrect answer
    P.S
  2. Jony130
    Feb 17, 2009
    3,991
    1,116
    I don't see any picture ??
  3. Jony130
    Feb 17, 2009
    3,991
    1,116
    First you need to find voltage across RL when the load is disconnect.
    The open circuit voltage Vab = Vth
    The second step is to find the current flowing from a to b when a & b are shorted together.
    And then Rth = Vth/Isc
    So know sow as your solution
      File size:
      9.5 KB
      16
      File size:
      9 KB
      22
  4. Digit0001
    Mar 28, 2010
    89
    ok for Vth i get
    (9-Va)/2 = 3Vx-Va
    2(2Va) = 9-Va
    4Va = 9-Va
    5Va = 9
    Va = Vth = 9/5
    Then when i find In = (33/6)/4
    so R = Vth/In = (9/5)/(In) = 4.4 ohms
    What is wrong?
  5. jegues
    Sep 13, 2010
    735
    43
    You wrote your KCL(or nodal analysis) incorrectly,
    You wrote a "current entering the node = the other current entering the node."
    Just write a simple KVL around the loop and express Vx in terms of the current flowing, solve Vab.
  6. Jony130
    Feb 17, 2009
    3,991
    1,116
    Simply nodal equation
    (9-Va)/2 + 3Vx-Va = 0
    Or we can write one equation like this
    I = (9V - 3Vx) / ( 2Ω + 1Ω) = ( 9V - 3Vx)/3Ω
    I = (9V - 3(2Ω*I))/3 = (9V - 6I)/3
    I = (3A - 2I)
    3I = 3A
    I = 3A/3 = 1A
    And Vx = 3*(1A*2Ω) = 6V
    Vth = Vx + 1A*1Ω = 7V
