Thought I would ask here before I have the chance of asking my lecturer tomorrow.
I have a problem question which asks me to manipulate some block diagrams to find the open loop and closed loop transfer functions and then draw a root locus of the system. Easy done that and all is verified as correct.
Next part (the bit I have difficulty with but i have a feeling is really easy.)
The problem asks me to calculate the value for K which would give a damping ratio of 0.6.
Now I assume I have to draw on my root locus a radial line from the origin for the damping ratio of 0.6 and then where the root locus intersects with this line is my K value.
How do I calculate this line? or do I have to use another method problem is the Characteristic equation is third order.
anyway if this helps the OL TF is (10s+k)/s^2(s+6)
I have the Characteristic equation as s(s^2+6s+10) + k = 0
plotted the root locus of the 3 poles 0, -3+j, -3-j
with asymptotes angles of +60 -60 and 180
starting point of -2
break points of -1.18 , -2.18
anyway hope someone can give me a pointer in the right direction have a feeling this is just a simple solution I am missing.
