Quick Question
Discussion in 'Homework Help' started by fishguts, Sep 19, 2007.
  1. fishguts
    Sep 3, 2007
    22
    I am trying to find the time constant for a circuit.I want to make sure I am doing this right. My resistor is 10K while my capacitor is 5pf. this would give me:
    T=RC
    T=10X10^3X5X10^-12
    T=10,000X.000000000005
    T=.00000005s
    then .00000005s would convert to .05ns right?
  2. niftydog
    Jun 13, 2007
    95
    You were right until the last step.
    0.00000005s = 50ns
    I prefer to stay away from all those zeros and use the sum of the exponents. In this case you just do this;
    10 x 5 = 50
    Now add the exponents;
    3 + -12 = -9
    ^-9 = nano so it's 50ns
  3. fishguts
    Sep 3, 2007
    22
    alright thanks alot. I am not that great with exponents yet, but I am practicing.
  4. fishguts
    Sep 3, 2007
    22
    I have oe more question. I am trying to figure out the capacitor coltage after a certain time but I am stuck on using the formula I cant understand it at all. Does anyone know anylinks that explain how to use the formula better? I tried reading the article on this website but it was not any help.
  5. niftydog
    Jun 13, 2007
    95
  6. fishguts
    Sep 3, 2007
    22
    The part that is confusing me is the exponent part where it is t/T. I have no idea how the examples are getting the numbers they are getting in their solution at that part
  7. niftydog
    Jun 13, 2007
    95
    Small t is the time in seconds at which you want to know the voltage.
    Big T (actually the greek letter tau) is the RC time constant (T = R x C).
  8. fishguts
    Sep 3, 2007
    22
    ok I got the formula down. I have one more question
    I have a problem that says to plot Vc for 0<t<4t using at least for points. what does it mean by this notation of 0<t<4t? I have never seen a problem like this before
  9. niftydog
    Jun 13, 2007
    95
    t has to be defined before it can be used in this context, so unless they say "t=0.5s" or something then t is meaningless. You sure it's not "T" rather than "t"?
    "0<t<4t" just means to plot the "t" axis from 0 up to "4 x t".
  10. fishguts
    Sep 3, 2007
    22
    here is an attachment if it helps
    it is number 3b.
    • hw4.pdf
      File size:
      107.3 KB
      19
  11. JoeJester
    Apr 26, 2005
    3,402
    1,225
    In your problem, you are going from time zero ( 0 < t ) to four time constants ( 4 tau ) .
    You were given that tau is 2 mS ... so they wanted the plot to 8 mS.
  12. fishguts
    Sep 3, 2007
    22
    alrigt thats what I was kinda thinking. thanks for the help!
  13. niftydog
    Jun 13, 2007
    95
    Yes, look closely, the t after the 4 is actually "T" or tau, not "t".
