Quick Question
Discussion in 'Homework Help' started by mattm, Sep 15, 2009.
  1. mattm
    Aug 5, 2009
    19
    in equal diode rectifier circuits and semiconductor diode has a high output voltage than a vacuum-tube diode and gas-tube diodes correct?
  2. JDT
    Feb 12, 2009
    658
    85
    Generally, a semiconductor diode has much lower voltage drop and lower internal resistance than a vacuum-tube diode so the output voltage in a similar circuit will be higher.
