quick question on veroboard...
Discussion in 'General Electronics Chat' started by JohnnyD, Sep 5, 2006.
  1. JohnnyD
    Aug 29, 2006
    79
    For the time being I'm still using veroboard for my projects. I use my dad's model railway track cleaner thing that looks like an eraser and is very slightly abrasive to clean the veroboard tracks before soldering. I find it makes the solder flow really well but the problem is that when i've finished and take a look at the copper tracks a week later they've all gone really dull, like they've corroded, as if by cleaning it i've removed some kind of anti-corrosion coating.
    So, is it best to cut the board to size, clean it and then give all the copper tracks a thin coating of solder? What else can I do?
    Thanks,
    John.
  2. Joe S.
    Member
    Aug 28, 2006
    10
    There are tin plating solutions available, I believe GC used to sell one, all you do is dump your circuit board into the solution and remove it and rinse a few minutes later, your copper is now silver colored as it now has a thin tin plated surface.
    you can buy a kit from:http://www.caswellplating.com/kits/tin_plate.htm
    check around to see if GC Electronics still sells this stuff, it was only about 6 bucks then, so maybe double now.
  3. JohnnyD
    Aug 29, 2006
    79
    Thanks a lot, the company i get my parts from sells this stuff, it's about £12 so pretty expensive but it should last ages. Hopefully it won't corrode so quickly!
