Quick Question on SuperNode
Discussion in 'Homework Help' started by Digit0001, May 29, 2011.
  1. Digit0001
    Mar 28, 2010
    89
    Hi
    In general can someone tell me if i have a circuit like the ones below can i made them a supernode?
    P.S
  2. Kermit2
    Feb 5, 2010
    3,852
    968
    Yes. IF The current that enters the super node will be the same as the current leaving, then solving the individual nodes is not required, and one can use that as a super node.
  3. Digit0001
    Mar 28, 2010
    89
    ok the following circuit has the exact circuit i have described above. I am having trouble trying to get the correct answer which is Vo = 22.34.
    This is what i have done
    1st equation using KCL
    528=24V1 + V2
    2nd Equation using KVL
    -4i + 2Vo + V2 = V1
    where i = V1 - 2Vo-V2
    where V1 = Vo
    -4(V1-2V1-V2)+2V1+V2=V1
    7V1+5V2=0
    V1=-5V2/7
    sub back into 1st equation and we get
    528 = -120V2/7 + V2
    3696 = -113V2
    V2 = -32.707
    V1 = (-5*-32.707)/7
    So V1=Vo=23.36volts
  4. jegues
    Sep 13, 2010
    735
    43
    I'm not seeing how you get your equations.
    Writing a super node at the top with the 4Ω and the dependent voltage source(labeling left node Vo, right node Vx),
    \text{KCL:}\quad 3 = \frac{3}{2}V_{o} - 30 + \frac{1}{16}V_{x}
    But from the supernode,
    V_{o} - V_{x} = 4 \left( \frac{-1}{2}V_{o} + 30 - V_{o} \right) + 2V_{o}
    \Rightarrow V_{x} = 5V_{o} -120
    Into my KCL,
    33 = \frac{3}{2}V_{o} + \frac{1}{16}\left( 5V_{o} - 120 \right)
    \Rightarrow Vo = \frac{81}{2} \times \frac{16}{29}
    Hopefully that clears up your confusion.
    Next time tell us what nodes you are labeling what, your equations aren't clear at all.
    Digit0001 likes this.
