I have this circuit constructed, alternating LED flasher. They flash too fast. I want each LED lit for only half of a second. Can I just replace the 47k with a higher resistor?
Ok, so I went up to a 120k in place of 47k and I could not see any difference. Should I go even higher?Yes, that should do it.
Argh, I thought I could get around having to do that. Will try it.Hello,
Take a look at this page.
http://www.play-hookey.com/digital/experiments/rtl_astable.html
You can enlarge the capacitors to slow down the circuit.
Greetings,
Bertus
