Quick question about Triangular Generator
Discussion in 'General Electronics Chat' started by Dritech, Nov 9, 2014.
  1. Dritech
    Sep 21, 2011
    756
    5
    Hi all,
    When I Google Triangular Generator, all circuits provided are formed from a schmitt trigger connected to the negative input of an integrating circuit. This causes the triangular output to be inverted from the square wave.
    Is it possible to connect the input of the integrator circuit to the positive terminal instead? Will this work? and do I have to use a different feedback layout?
    Any help would be appreciate.
    Thanks.
  2. Alec_t
    Sep 17, 2013
    5,968
    1,135
    No. If you need to invert the waveform then use an additional inverting opamp.
    Lundwall_Paul and Dritech like this.
  3. Dritech
    Sep 21, 2011
    756
    5
    Also, in the attached 2 steps, I can understand that (R2/R2+R2)Vsat changed to -(R2/R2+R2)Vsat
    but what exactly happened to -Vramp? and how did R2 in the denominator changed to -R3?
    I really cannot understand what happened in these 2 steps.
  4. Alec_t
    Sep 17, 2013
    5,968
    1,135
    Your circuit doesn't show a Vramp node. Presumably Vramp = V0 (the output of A2)?
    R2 and R3 form a voltage-divider. The voltage at the top is V0', and at the bottom is Vo. Therefore the voltage across the divider is Vo'-Vo and so the voltage at P is V0 + (Vo'-Vo)*R2/(R2+R3).
  5. Dritech
    Sep 21, 2011
    756
    5
  6. Alec_t
    Sep 17, 2013
    5,968
    1,135
    The linked article has only 43 pages :confused:. I don't see those steps anywhere, nor R2 replaced by R3. 5.6 is the relevant section.
    Ground is common; not Vramp (the A2 output). The text is confusing because the author uses '-Vramp' to denote the negative part of the triangle.
  7. Dritech
    Sep 21, 2011
    756
    5
    Sorry I think it was another pdf. I cannot find the file, but I have this screenshot of the derivation. From this part I cannot understand how R2 changed to R3 in the numerator. Also, what happened to -Vramp?
    Thanks in advance.
  8. Dritech
    Sep 21, 2011
    756
    5
    Sorry forgot the attachment.
  9. Veracohr
    Jan 3, 2011
    559
    77
    Combine the two Vramp terms.
  10. Alec_t
    Sep 17, 2013
    5,968
    1,135
    -Vramp+Vramp\times\frac{R2}{R2+R3} = Vramp\times(\frac{R2}{R2+R3}-\frac{R2+R3}{R2+R3})=Vramp\times\frac{-R3}{R2+R3}
    Dritech likes this.
