Quick question about shift registers
Discussion in 'General Electronics Chat' started by jaygatsby, Dec 29, 2011.
  1. jaygatsby
    Nov 23, 2011
    185
    23
    I want to use three 8 bit shift registers to enter / latch 24 bits. I see several 8 bit shift registers on Jameco. Is it normal to 'chain' shift registers together, 3 in my case, to obtain a desired bit width? Or is that not how they work?
    Thank you
  2. crutschow
    Mar 14, 2008
    13,473
    3,361
    Yes, you can "chain" them to give as many bits as you need.
    jaygatsby likes this.
  3. SgtWookie
    Jul 17, 2007
    22,183
    1,728
  4. thatoneguy
    Feb 19, 2009
    6,357
    718
    If you are tying them together for an LED matrix, take a look at the Maxim line, they are I2C controlled, and are programmable current sinks for dimming and other features LED billboards use. MAX6956.
    I was sent some samples and am extremely impressed, especially since they can be another 28 I/O ports instead of constant current sinks for LED driving, or a mix and match of both I/O and LED current sinks.
  5. jaygatsby
    Nov 23, 2011
    185
    23
    What I intend to do is have a keypad connected to the shift registers. The registers Sgt gave look like they will work well. I'll use the keypad connected to the chip serial inputs (i'm using 3 chips), and the outputs will go to counters... when the user presses enter on the keypad the jam inputs of the counters will read from the output of the shift registers.
  6. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    You might find it interesting that you only need one pin to shift out data into the registers, and latch it into the outputs. :eek: ;)
    Have a look at this page on Roman Black's site:
    http://www.romanblack.com/shift1.htm
