Quick question about open loop / closed loop op amps and mosfets
Discussion in 'Homework Help' started by hrstar24, Dec 13, 2010.
  1. hrstar24
    Thread Starter Active Member
    Apr 7, 2009
    32
    So with the following circuit (Q1 and Q2 are matched, as well as Q3 and Q4):
    How do I go about calculating the overall small signal gain of the circuit?
    So far I am just assuming that since IN- is connected to Vout, this circuit is just merely a voltage follower op amp, so the gain from the differential amplifier (Q1 - Q4) is 1. This means I only need to worry about the gain from Q5 right?
  2. Ron H
    Apr 14, 2005
    7,050
    657
    The closed loop gain is exactly 1 only if the open loop gain is infinite. You have to calculate the open loop gain (loop broken between Q5S and Q2G) before you can calculate the closed loop gain.
  3. hrstar24
    Apr 7, 2009
    32
    Ok I have calculated the open loop gain of the circuit, so how do I go about getting the closed loop gain once I have the open loop gain?
    I have this equation:
    Vout = Vin ( K / (1 + K/A))
    where K is the closed loop gain, and A is the open loop gain. Since this is just a simple voltage follower, we make K = 1, plug in the open loop gain, and solve for Vout/Vin. Is this the correct approach?
  4. Ron H
    Apr 14, 2005
    7,050
    657
    The equation I am familiar with is
    Vout/Vin = A/(1+Aβ)
    where A is the open loop gain and β is the feedback ratio.
    I suppose your equation solves for actual closed loop gain, given ideal closed loop gain, so that's another way to do it. I hadn't seen that method.
    hrstar24 likes this.
