Quick Question about a Circuit
shteii01
Joined Feb 19, 2010
4,644
It looks like 0 volts (ground) is connected to Pin 7. 12 volts is connected to Pin 14.
Those are usually Vcc and Ground pins on most chips in DIP package. The bottom left pin and the top right pin.
I take it they are using quad AND logic gate chip?
bertus
Joined Apr 5, 2008
22,276
@ shteii01,
The TTL chip you show will blow at 12 Volts.
MrChips has shown the correct pinout.
Bertus
shteii01
Joined Feb 19, 2010
4,644
@ shteii01,
Bertus
It is not my intention to tell OP which part/model number to use.
My intention is to show OP the function of certain pins. Pins 7 and 14 to be precise.
bertus
Joined Apr 5, 2008
22,276
There are also TTL chips with the power on the pins 5 and 10.
Have a look at some of the counterchips.
Bertus
shteii01
Joined Feb 19, 2010
4,644
Bertus
The OP schematic does not have power and ground on pins 5 and 10. Why should I waste my time on things that OP is not asking about.
