Quick power supply question
Discussion in 'The Projects Forum' started by PlayaSlaya, Mar 24, 2010.
  1. PlayaSlaya
    Jun 22, 2009
    16
    Hi, heres a power supply i designed to deliver 5V and 3.3V. Can anyone tell me if it will work.
    Any help is much appreciated. Thanks
  2. PlayaSlaya
    Jun 22, 2009
    16
    Sorry, i forgot to attach the circuit digram.
  3. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Change R1 to 120 Ohms. Change R2 to 200 Ohms.
    For more stability, connect a 10nF cap between the junction of R1/R2 and ground.
    You need larger filter caps after the rectifier bridge. 2,200uF would be OK for up to around 500mA.
    Don't forget to use heat sinks.
