Quick MikroC Interrupt ?
Discussion in 'Programmer's Corner' started by Dalaran, Jan 8, 2010.
  1. Dalaran
    Thread Starter Active Member
    Dec 3, 2009
    168
    What is the identity used to call the interrupt service routine in MikroC?
    Code ( (Unknown Language)):
    1. void interrupt my_isr(void){
    2. }
    That I used in MPLAB is not working.
    Thanks.
    edit: my bad wrong forum, should be uC.
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    See the mikroC Manual.
    In the version I downloaded in August 2008, it's in the mikroC Language Reference under mikroC Specifics, on page 36.
  3. Tahmid
    Jul 2, 2008
    344
    27
    You got it wrong.
    It should be:
    1. void interrupt(){
    2. // your interrupt handling code here
    3. }
