figred out
This is where you went wrong.Current heading up from 20,000 resistor in (bottom) Op-amp = 1/20,000
Vout2 for second (bottom) Op-amp = -(1/20,000)*40,000
For the amp (lower left hand) in question....isn't it 1 minus the drop across the resistor from the logic shown here:
http://www.youtube.com/watch?v=2SwT...es/detail/embed20.htm&feature=player_embedded
@ 22:30
Vout2 = 1 - (1/20k)*40k
Thread starter | Similar threads | Forum | Replies | Date |
N | Quick check: 12V Lead Acid battery for stepper motor | Power Electronics | 2 | |
G | Quick simplification check | Homework Help | 15 | |
FSM Question (Quick Check). | Homework Help | 4 | ||
Counter and Shift Registers (Quick Check) | Homework Help | 4 | ||
Quick Nodal Analysis (Check) | Homework Help | 3 |
by Dale Wilson
by Duane Benson
by Duane Benson
