Quick arduino schematic question
Discussion in 'Embedded Systems and Microcontrollers' started by Shackdaddy836, Oct 28, 2011.
  1. Shackdaddy836
    Dec 13, 2010
    Hey, I have this MP3 player shield schematic and I'm trying to find 5 I/O ports that I can hook up an LCD to. Problem is that this shield is connected to basically all of the I/O ports. Can someone help me look on this schematic to see if there are any pins that I can connect multiple things to?
    Here's the schematic:
    http://dlnmh9ip6v2uc.cloudfront.net/datasheets/Dev/Arduino/Shields/MP3 Shield-v13.pdf
    Not including the analog pins BTW. I know you can convert those but I need those for something else :)
    Thanks a ton for the help.
  2. hgmjr
    Jan 28, 2005
    You could use a scheme involving 3 IO lines and a shift register similar to the one depicted in this link.
