http://img162.imageshack.us/img162/6152/64347540.jpg
not much to explain, I've showed my work there...
does that look right?
If one path is a short and the other a resistance though, ALL of the current will flow to the short I guess...
Yes, your terminology is incorrect. Current does not flow. Current exists. Charge flows. Current is charge flow. To say "current flow" is to say "charge flow flow". The world does not seem to realize that or does not care. Current has a value, but it does not flow twice.I'm confused now though...
The charge flow is determined by the easily derived and widely used current division principle. The current in R1 of a two resistor parallel circuit is It*R2/(R1+R2) . If R2 is open, the current in R1 is It. If R2 is shorted, then the current in R1 is zero.So I suppose the case is that if I have two paths that BOTH have resistances, the current will be split up with more of it going to the lesser of the two resistances, but still some current going to the other path nonethless...
by Jake Hertz
by Duane Benson
by Duane Benson
by Jake Hertz
