Telepohone distribution networks are playing an important role in datacommunication what's teh main step involve in processing teh signal in switch room of PSTN?
Q2*A controlling teh speed of a motor .the 0 to 1mv analog voltage from DAC is amplified to produce motor speed from 0 to 10,000 rmp.how many bits should be used if the computer is to be able to produce a motor speed thatis with in 1rmp of the desired speed?
how many bits to be generate by teh computer to control the 25,00 rmp of teh motor?
kindly show the answer.THAnks
