You are correct that there will be a reflected wave if the load is not matched, and the reflected wave is traveling the other way by definition. And correct that negative real part of normalized resistance means reflection coefficient with magnitude greater than one.Unless the load impedance equals the line impedance there will be a reflected component.
Surely the negative sign implies that the 'reflected' wave is greater than the incident?
And is the reflected wave not travelling the other way?
I think it more like your were saying before with a resonant circuit, the unloaded gain can appear to be > unity but as soon as real power is drawn from it we see normal circuit behavior. So if we have a complex Zo (input impedance contains a negative real part) we can see this strangeness but it's not really strange if we understand the whole picture with something like a tunnel diode circuit where at some frequencies it's input immittance might have it's real part negative.The OP is worried that his example shows the magnitude is greater than one, which seems strange. The first impulse is to say that this violates energy conservation, but we must remember that the field is not the same as the power. Typically, field squared (or voltage squared) indicates power, but the case of complex Zo is a little different because the current and the voltage are not in phase any more. Hence, I think we need to be more careful in defining the wave power.
I'm still thinking about this question. I've made some progress, but am holding off on giving an answer until I'm sure. However, here are some values I ran across in "The Electromagnetic Field" by Albert Shadowitz, chap 16.I've tried going to cable manufacturer's websites and getting numbers for {L,C,G,R} per foot and haven't had much luck. Of course, I have nomincal L and C numbers from the geometry and can probably estimate G and R values from knowing the materials and dimensions.
I think that, strictly, loss means the wave is not TEM, but it is usually a very good approximation to consider them to be TEM, if the lossless solution is TEM. In general there can be nonTEM solutions in transmission lines and waveguides of various sorts, even in the lossless case.The problem I have is that we know that, in general, the characteristic reactance of a real transmission line does not have to be zero and, it is my understanding from people that work with RF PCB designs, that the characteristic reactance can be significant. I wanted to hang my hat on the claim that as soon as you have a characteristic reactance that you no longer have TEM waves, however I have found several places where the discussion implies that it is still valid to talk about lossy transmission lines under the assumptions of TEM waves and that non-TEM waves start developing only at much higher frequencies (and that the point at which this happens is a limiting parameter for the transmission line).
I think that when the various texts say to divide by Zo, they don't mean that you should keep the units attached to that denominator. I think of normalization as a scaling process; I take the divisor to be just a number which is the numeric magnitude of Zo.Leaving all of that aside, my confusion stems from the fact that normalized impedance is not an impedance at all, it is the ratio of two impedances. Thus the real part of the ratio is not a "resistance" and the imaginary part is not a "reactance"; they are both dimensionless quantities.
There are some values for a number of cables here:However, here are some values I ran across in "The Electromagnetic Field" by Albert Shadowitz, chap 16.
"Typical values for an open wire transmission line are R=4 mOhm/m, L=2 μH/m, G=0.2 nMho/m, C=6pF/m, alpha=3 μNp/m, beta=20 μrad/m."
Note that these values indicate a wave speed of 0.962 times the speed of light in vacuum and a characteristic impedance of 577 Ohms. Obviously there are transmission lines that are significantly different than this, but this gives one example to consider.
There is no need to just "throw away units" -- doing so is unjustified and, as far as I'm concerned, unforgivable. When you normalize to a reference impedance, such as Zo, then the units will go away automatically because normalizing (usually) involves dividing the non-normalized value by the reference value. When it doesn't, then the surviving units must be tracked. For instance, the cable parameters (R,G,L,C) are normalized on a per-unit-length basis. But in this case the normalization does NOT result in a units cancellation and it is critical that the units be properly tracked. The results will be very different if someone used L in Henries/meter and C in Farads/foot.I think that when the various texts say to divide by Zo, they don't mean that you should keep the units attached to that denominator. I think of normalization as a scaling process; I take the divisor to be just a number which is the numeric magnitude of Zo.
Yes, and I imagine that cable manufacturers go to great lengths to make cables for which this is a perfectly reasonable assumption to make. But there are transmission lines that are not carefully designed and engineered cables, such as microstrip lines on a PCB made using tracks. My understanding, again from talking with people that have experience with them, is that these can have significant reactive components to the characteristic impedance.I have never seen a numerical example where the actual Zo of a real cable was used, such a Zo typically having a small non-zero complex part. I've always seen the nominal impedance used.
And, the nominal impedance of a cable is usually taken to be a pure resistance.
FYI: I am just getting into electromagnetics, so please keep explanations close to the basics and fundamentals, if possible. Thanks.
I have run across the claim, in numerous texts and online resources, that the real part of the normalized impedance (the ratio of load impedance to the characteristic impedance of the driving transmission line) can never be negative, except in the case of some active devices. The justification I have seen for this in several places is that, for passive circuits, negative resistance has no physical meaning.
More to the point, consider the following example:
Load: ZL = 50+j1000 ohms
Transmission line: Z0 = 50-j3 ohms
It would seem to me that the normalized impedance in this case would be:
Normalized impedance: Zn = ZL/Z0 = -0.2+j20
In fact, it would seem that as long as the transmission line has any reactive component at all, that a passive load could easily be constructed that would result in the real part of the normalized impedance being negative.
So what am I missing?
What would happen if I proceeded to build such a circuit? Is there something that makes such a circuit unrealizable?
Certain passive devices (tunnel diodes) also exhibit negative resistance regions.It would indeed be difficult to plot a negative real resistance on a Smith Chart, since the left extreme is 0 ohms (whether normalized or not). As you suggest, for passive devices, negative resistance has no meaning. A signal generator, on the other hand, can be interpreted as a negative resistance device. Also certain active devices exhibit negative resistance over some part of their operating range (see references on "tetrode kink").
Eric
Is it? If I have a huge transformer that is unloaded, it will look like a large inductive load to the source, right? I would not expect that to change much if I barely load it by terminating it with a very large resistor, hence I would expect it to still look like a large mostly inductive load, wouldn't I? I would expect the input impedance to go asymptotically toward a real load only as the load get heavier and heavier (R approached zero) and even then only if there is perfect coupling between the primary and secondary.An ideal transformer has no real (dissipative) resistance, and yet if you terminate it with a real resistance, the input impedance is REAL.
Is this true even if the characteristic impedance of the transmission line has a reactive component?Another case is that of an infinite length transmission line. Although there is no "real" resistance to burn up any power, the input impedance is real.
Basically, any time there is real power transfer away from the electrical circuit, whether it be energy dissipation, energy propagation or energy conversion (i.e. sound, light, electromagnetic wave etc.), it must appear to be a real impedance to the electrical source.I forgot where my train of thought was on this....but here's another interesting point. An ideal transformer has no real (dissipative) resistance, and yet if you terminate it with a real resistance, the input impedance is REAL.
Just some more intuitive thoughts.
Eric
By the way, I always thought of a tunnel diode as an active device. I guess the definition is debatable.WBahn said:Certain passive devices (tunnel diodes) also exhibit negative resistance regions.
I'm really struggling with this notion that both you and KL7AJ seem to be putting forth. I fully agree and understand that the impedance must have a real component commensurate with the real power that is extracted, but I do not understand why the impedance is now real; Why can't it still have a reactive component, as well?Basically, any time there is real power transfer away from the electrical circuit, whether it be energy dissipation, energy propagation or energy conversion (i.e. sound, light, electromagnetic wave etc.), it must appear to be a real impedance to the electrical source.
That's the sense I'm getting. The definition I was taught (back in the very first course that introduced transistors) was that "active" meant that it had the ability to increase the power in the signal, which in turn meant that there had to be some means of taking power from an external source and adding that to the signal. But as I was just looking on the internet, it does seem like there are different definitions and some of them say that it is also active if it has the ability to amplify a signal in any way or to electrically control the flow of current (i.e., has 'on' and 'off' modes that are electrically determined). Yet on those same sites, some claim that regular diodes are passive while others say that all semiconductor devices, including LEDs, are active. Based on the snippets in the Google results page, it appears that some definitions base it on whether the small-signal model of the device includes any supplies (independent or dependent).By the way, I always thought of a tunnel diode as an active device. I guess the definition is debatable.
I'm just latching on to the idea from KL7AJ, that this is an "interesting point".I'm really struggling with this notion that both you and KL7AJ seem to be putting forth. I fully agree and understand that the impedance must have a real component commensurate with the real power that is extracted, but I do not understand why the impedance is now real; Why can't it still have a reactive component, as well?
I will certainly agree with that!I'm just latching on to the idea from KL7AJ, that this is an "interesting point"....There is a real dichotomy between the circuit view and the field veiw here.
Thread starter | Similar threads | Forum | Replies | Date |
S | Basic Questions Regarding NOR and NAND | Homework Help | 0 | |
E | General questions regarding splicing wires | General Electronics Chat | 22 | |
M | Questions regarding look up tables | Digital Design | 18 | |
N | Couple of questions regarding this photocell circuit. | Power Electronics | 13 | |
A | A few questions regarding Mosfets | Analog & Mixed-Signal Design | 2 |
