Problem nr1.
By considering the basics of the components of electricity(magnetism and dielectricity) and hence the way condensers and inductors behave, and hence the parallell RLC circuit.
How do i make the oscillation between the inductor(s) and the condenser(s) more inert in the sense that the oscillation between it lasts as long as possible when i remove the power source from the circuit, and the resistor ,in this case for simplicity, is a lamp between the L and C.
Since my knowledge is superficial and theoretical.
The higher the inductance and capacitance the higher the electrical inertia.
But when the energy storage becomes high wont it become a filter and hence try to kill the oscillation when the frequency is low (30-400hz)?
Question nr2.
How do i make a multi-bandpass filter from different filters so that their properties dont mix with each other creating another different filter.
Question nr2.
