In the photo above, I'd like to know how much wire, and what size wire, to wrap around the legs of those Ferrites you can see in the bottom of the photo, in order to charge the large Cap.
The Large cap should bleed off through the small solenoid which will pull up, and hold, and allow a fluid to flow.
Tell me all you know.
PS: I forgot to go back to the Paper clip and follow through. Scuse me!
